configure igmp snooping vlan ports delete static router
configure igmp snooping vlan vlanname ports portlist delete static router
Description
Removes the configuration that causes VLAN ports to forward the traffic from all multicast groups, even if no IGMP joins have been received on the port.
Syntax Description
vlanname Specifies a VLAN name.
portlist Specifies one or more ports or slots and ports. On a SummitStack, it can be a list of slots and ports. On a standalone switch, can be one or more port numbers. May be in the form 1, 2, 3-5, 2:5, 2:6-2:8.
Default
N/A.
Usage Guidelines
This command is used to remove a static router port entry created on a VLAN. Use this command to remove an entry created by the following command:
configure igmp snooping vlan vlanname ports portlist add static router
The following example removes the static IGMP entry that caused all multicast groups to be forwarded to VLAN marketing on ports 2:1-2:4:
configure igmp snooping marketing ports 2:1-2:4 delete static router
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IGMP snooping feature, see the Switch Engine v33.1.1 Licensing Guide document.
